| Message |
I converted my 92 twin over to an n/a ps pump when I replaced the alternator. I'm finishing up the conversion and trying to button everything up and I've run into a problem. I rebuilt the p/s pump and used the proper aluminum bracket, as well as the other metal bracket which is longer on the n/a pump, and I also used the tt pulley so I could still use my fairly new 4 rib belt. Anyways, I go to tension the belt today and when I get it tensioned down, the belt lightly rests up against the main body of the crank pulley. I know when the car is fired up it'll rub up against it and chew up the belt. Anyone care to offer up their .02?
